1 - 19 of 19 Posts
ok i have a 2001 with 214k miles
tymar intake
4"diamond eye exhaust
edge cts evolution
the truck seems to be having a prob it has lost all its power at take off. like i am afraid to turn in front of someone cause of its slow take off... it wasnt like this when i first got it ......also my turbo shutters when towing and going up a hill
my ? is what can i do with my cts to diagnose my prob
Have you checked the intercooler boots for boost leaks?
Start with the simple stuff first. Check your air, fuel and oil filters. Not familiar with the CTS but if you could check ICP and boost it would help.
boost on the highway with it hammered to floor is around 18psi cruising on highway doing 65ish boost is 0-2psi
didnt really see much soot on turbo pipes
Fuel pressure possibly.
well its not a stock truck......
and what kind of diagnosis can I do with my edge CTS????? fuel pressure ???can it be checked by the cts?
Fuel pressure needs it's own gauge. No OEM sensor.
Could be the pedal sensor. I swapped mine cause either was acting kinda the same way( I had already checked fuel pressure, icp, air filter ect ...) and it made a world of difference. But you really need it on a good data logger or scanner to see what the computer is seeing as far as throttle pedal position....-
Discussion Starter #12
i thouhjt the edge cts could data log
I don't know exactly what it can do, but I know it can't do throttle position sensing...
Discussion Starter #14
also fuel mileage has went to ****..... i have changed the map sensor and waste-gate solenoid ,,,,,,, and when in park if i rev it up like to 2500 rpm or so it barley gets 1-2 psi of boost ..... any help asap please im leaving for a road trip thurs.... also checked all intercooler lines and boots and all are good..... how can i check for a boost leak????
you won't get boost sitting still. Gotta load up the motor.
pressurize the system to check for leaks
I made my Samsung SGH-I997 send this.
Discussion Starter #16
ok so i pressure tested it and it held pressure with no leaks....... what else could it be?
too many possibilities til you scan it. if boost is normal, turbo is ok, as is probably fuel delivery. possibly fuel timing, or heui pressure
Ebpv stuck closed?
1 - 19 of 19 Posts
