My 2000 F250 has a swd and I tow a 12,500 5th wheel. I am a little concerned about getting stuck since only one wheel grabs. Has anyone installed a locker or posi-trac unit in their swd? If so, what are y'alls recommendations? Should I even be concerned?
Its kind of a toss up.... Ideally you want a selectable locker or limited slip. Turn the locker off when driving/not concerned and on if you get nervous. You could try something a little more though if you are interested.... Youkon is pretty standard for lockers and limited slips. But a full locker that cant be turned off is just going to wear the tires out and make things miserable on corners.
-Front receiver hitch less than $200 from etrailer
-Harbor freight 12k winch maybe $400 with coupon maybe little more $$ but the synthetic rope will save 50+lbs.
-winch basket $100ish all over internet
-$50 misc thick guage wire and quick connector
Now you can store it in the garage when not needed and throw it on when you travel. May not be more expensive than parts and labor for the rear end for most folks. Esp since you probably aren't going into crazy mud areas with a 5th wheel and its rolling weight so 12k is plenty to give yourself a nice bump.
My dad has had a locker in his e350 for many years now. It’s great for traction, but can be a little irritating at times, mostly at intersections in the rain. Overall though, it’s worked out well for him
True Trac. Gear driven torque bias. They are magical. I have the factory Eaton in my truck and have considered installing the TT instead. Parking our toy hauler in the field, the factory locker kills the turning radius.
I would only run a non selectable locker in a more off-road style rig. My desert truck had one for a long time, didn't hate it on the street, but you know it's there and it likes to remind you. I wouldn't want that in my tow rig. I would definitely do some type of limited slip setup.
You talk about what you tow, but not where you plan to drive.
I have a 4wd, but have rarely had to lock the 4wd in even on my ranch, and I think mine are open diffs. These truck are so heavy, if you end up getting stuck, I am not sure a locker would get you out.
Depending on where you plan to drive, I would likely roll the dice and see when If I got stuck. If I did get stuck, I would do what Justin suggested, get a front reciever, and a winch. I think this would be a better investment.
I have a selectable locking rear end on my Ford Sterling rear end. I have a Eaton True Trac on my front end since I have Eaton Dana axle in the front. They work well together. I also have a winch on the nose.
You can't go wrong with a Detroit Truetrac, I have one in my Excursion rear axle and it works so well on snow, sand, mud, everything.
