1 - 5 of 5 Posts
Do any of you guys know what bulbs are used for things like the ABS light on the dash? I need to replace it but would like to have the correct bulb in hand before pulling the dash apart.
Does the dashboard bezel have to come off first (the part that extends around the stereo), before the instrument cluster will come out?
Not sure on the idiot light bulbs, but the process I used to pull my cluster was
  1. Pull Radio
  2. tilt wheel all the way down
  3. put on parking brake and put shift selector into 1st (should probably put a wheel chock at a wheel or 2 to keep from rolling away)
  4. Pull trim section that goes around cluster and radio off
  5. Pull off all connectors to switches left on trim
  6. 4 screws holding cluster
  7. disconnect odometer from cluster
  8. Pull cluster
The parts guy I talked to said there were three possible bulbs in the instrument cluster and he didn't know which one it used. Anyone else know for sure?
FYI: Gauge cluster illumination bulbs are 194, aka T3.25, all other warning lights and indicator bulbs are 37, aka T1.75.
1 - 5 of 5 Posts
