I just got 200K on the 6.0 and iv got one bad injector and bad egr cooler but should i pull the heads and R&R the heads and stud it,along with 8 injectors or just do one injector and delete the egr
If you can do everything. IMO
Lt. Negativity
IF your gonna upgrade injectors then yes replace all 8 if not if your other injectors are fine just replace the one. Get the egr delete, stud it, R&R and you should be good.
wow 200k on an 06 thats a lot of drivin
Are these the only problems you've had in 200,000 miles?
IMO, replace all 8 injectors so you dont have to pay for labor 8 different times.
any other problems in those miles?
