1 - 12 of 12 Posts
Ok, my buddie with a Duramx has stated running 2 stroke oil in his fuel tank. Has anyone heard of this or done it? He said the main reason is to lube injectors and other such componants that do not get oil. He said it also helps with noise, and mpg's. Just thought i would put this out there.
I have been using 1oz. per gallon for some time.....seems to quiet things down with the added lubricity.....Fred
Use the search function and you will find alot of information about this.
it no big deal. welcome and search has become my best friend.....also it is bad cause I just keep finding cool stuff the I want to do. :doh:
I run 1oz per gal in my diesel tank. truck like its. no change in MPGs just do it for the lube.
any certain type/brand? or just any ole 2 stroke oil? do you do this every time you put fuel in?
most people buy the walmart supertech. TCW3 in the gallon.. :) 11 bucks!
i went lookin for this the other day, i didnt see where it says ashless or not
Powerstroke Junkie
I wouldn't do this. It worked well in the OBS trucks, that and ATF but not in gthe SD. Our injectors are totally different animals with much tighter tollerances. I know many run it without any problems, that they are aware of. I have read of to many injectors going belly up after using these additives for awhile. YMMV.
1 - 12 of 12 Posts
