1 - 11 of 11 Posts
what does it mean when 2 of your injectors read -114 or so? i had mine checked today by a shop to see what my smoking issue is and i was told #6 injector was throwing a code but when read on the graph both #6 and 8 injector both read -114 or something like that?? .... not sure what that means? hoping yall could tell me? and is it wise to look for a wiring problem since both injectors side by side are reading bad or FICM problem? or could it just be both bad injectors any and all info is appreciated thanks
No idea what those numbers mean. Tell us whats going on with your truck.
Without knowing the scale of the graph those numbers mean nothing.
ok sorry i should have told you before.. it smokes heavy blueish white smoke that smells like raw fuel at idle and shakes and misses a bit but once you take off or floor it it puffs a cloud of black smoke and takes off .. after you drive it for a bit the smoke kinda goes away once you come back to idle but still shakes.. i had my truck scanned with a snap-on SOLUS scanner to run an injector pulse test and the -114 was on the injector pulse test graph for both injector #6 and 8 was lingering right around -110 to -114 also but the caodes on say #6 is bad.. does this help any?
Discussion Starter #7 (Edited)
Ok so i checked my electrodes on my FICM. and starting from driver side going towards passengers the voltages are as fallows ....
Key on engine off
#1 47v
#2 12v
#3 0v
#4 0v
engine running
#1 47v
#2 13v
#3 0v
#4 0v
what can i do? I thought if it had no voltage to one or more electrodes it wouldn't run?
I've never seen anyone test the other posts?
FICM testing procedure - Ford Truck Enthusiasts Forums
but you have 47 volts while it's running and have issues so I think the FICM is fine
ok i see now i misunderstood when i watched the videos on youtube on how to test it but i see now ... so my FICM is good im guessing? so i guess im sticking with replacing the #6 and 8 injectors... am i correct that they are bout the rear 2 on the drivers side?
That -114 is probably on the cylinder contribution test on a snap-on scanner. Essentially those cylinders aren't firing at all. A mild misfire will be around -35 and the cylinders should all read 0. I would say those injectors went out completely, are unplugged/harness problems, or you have an issue on those cylinders.
1 - 11 of 11 Posts
