Hello, I am in need of some help!
I have a 1999 SD with 213,000 miles on it.
This has happened a few times now. When I first start the truck up everything is normal. After I drive for about 300 yards going about 25mph the RPM's start to drop, it does not respond to giving it more throttle, then the engine shuts off. No engine lights come. I have tried putting it in neutral to restart the engine while coasting but it just cranks and cranks. If I stop put the vehilse in park take the key out then try to start the engine it will start as long as I pump the gas peddle. Both times after this happens the truck runs perfect for the rest of the day. Also the last two time this has happened it was wet outside. I did already swap out my CPS.
Any ideas?
Ryan
Any ideas?
Ryan
