I have a 1999 7.3 powerstroke and if I cycle the key like 5 times it’ll build up enough pressure to start then it’ll idle rough and blows out enough white smoke to fill the neighborhood then it’ll bog down and die And the fuel bowl has so much pressure you can open it and it’ll try to spit fuel out fill tube and when you do get bowl open it’s only 3/4 full and I just put a new fuel pump cause I thought that was the problem also sometimes it’s black smoke sometimes blue most the time it’s white
