So my truck started seemingly having a hard time revving up. While driving it seems like the fuel was cut, even with the accelerator floored it wouldnt rev past about 1300 rpm and as soon as I let off the gas the rpms bottom out and it shuts off. When it's running at idle its EXTREMELY rough and zero pedal response. Then all of a sudden, bam, full power and takes off like a rocket. Then it sputters out, wash rinse repeat. It doesn't seem to want to stay running sometimes, sometimes it doesn't want to start. It died last night at work and when I got her running this morning, I pulled this list of crazy codes:
Fault log report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Current Fault Log
ECU reports no current faults
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
B0000: Unknown code - More information may be available on the web
B2400: [Mitsubishi] KOS key registration fail
C0200: Unknown code - More information may be available on the web
C0980: Unknown code - More information may be available on the web
C0DC0: Unknown code - More information may be available on the web
C1271: [Mitsubishi] Motor drive circuit
C16C0: Unknown code - More information may be available on the web
C3380: Unknown code - More information may be available on the web
P0012: "A" Camshaft Position - Timing Over-Retarded (Bank 1)
P0044: HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0080: Exhaust Valve Control Solenoid Circuit High (Bank 1)
P00BC: Unknown code - More information may be available on the web
P00F4: Unknown code - More information may be available on the web
P00F5: Unknown code - More information may be available on the web
P00FF: Unknown code - More information may be available on the web
P019F: Unknown code - More information may be available on the web
P01B2: Unknown code - More information may be available on the web
P01DD: Unknown code - More information may be available on the web
P01E3: Unknown code - More information may be available on the web
P0220: Throttle/Pedal Position Sensor/Switch "B" Circuit
P029F: Unknown code - More information may be available on the web
P02D8: Unknown code - More information may be available on the web
P02E5: Unknown code - More information may be available on the web
P0341: Camshaft Position Sensor "A" Circuit Range/Performance (Bank 1 or Single Sensor)
P0428: Catalyst Temperature Sensor High Input (Bank 1)
P0431: Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0465: EVAP Purge Flow Sensor Circuit
P048E: Unknown code - More information may be available on the web
P0565: Cruise Control On Signal
P0568: Cruise Control Set Signal
P0578: through P0580 Reserved for Cruise Control Codes
P0603: Internal Control Module Keep Alive Memory (KAM) Error
P061F: Unknown code - More information may be available on the web
P0642: Unknown code - More information may be available on the web
P0750: Shift Solenoid "A"
P1000: [Ford] OBD-II Monitor Testing Incomplete
[Mazda] OBD II Monitor Testing Not Completed
P1194: Unknown code - More information may be available on the web
P1211: [Chrysler] Mass Air Flow Circuit Intermittent High
[Nissan] ABS/TCS Control Unit
[Dodge] Mass Air Flow Circuit Intermittent High
[Jeep] Mass Air Flow Circuit Intermittent High
[Seat/Audi/Volkswagen] Intake valves for cylinder shut-off Open circuit
P1284: [BMW] Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal Low
[Seat/Audi/Volkswagen] Fuel Inj.Air Contr.Valve Circ. Open
P13C9: Unknown code - More information may be available on the web
P1536: [Chrysler] Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
[Dodge] Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
[Jeep] Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
[Seat/Audi/Volkswagen] Intake Camshaft Contr.Circ.,Bank2 Open
P1663: [Chrysler] Oil Life Lamp Control Circuit
[Lexus] OCV Circuit Malfunction (Bank 2)
[Dodge] Oil Life Lamp Control Circuit
[Jeep] Oil Life Lamp Control Circuit
P1E00: Unknown code - More information may be available on the web
P23C0: Unknown code - More information may be available on the web
P2502: Charging System Voltage
P2503: Charging System Voltage Low
P2E3B: Unknown code - More information may be available on the web
P2E4E: Unknown code - More information may be available on the web
P3B40: Unknown code - More information may be available on the web
P3C00: Unknown code - More information may be available on the web
U2A1E: Unknown code - More information may be available on the web
End of report.
Is it me is my truck possessed by demons?
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
