97 F250 7.3 - I have KOEO codes p1283, p1662 and p0381, and a no start issue. There were no codes stored on the PCM; I just have the KOEO codes. I’m using the AutoEnginuity tool, and I know that I have low ICP (175 when cranking). I checked The ICP sensor and it’s ok. When I put 12v to the IPR, I get good pressure (2,400 psi). i checked the voltage signal while cranking and get 9.8 v or so to the IPR. IPR duty cycle is very high at 54.68. I checked the wires and dont see any abrasions. Also buzz test passed and sounded great. Am I pretty much down to a new PCM?
This problem started with slight misfiring, then bad misfiring, then no start...
I assume that the p0381 is a bad glow plug, so Im not worried about that for now.
