All on the same side and next to each other huh? Check the pigtail going to the that side of the head looking for damage/melting.
No, they're not. 4 is on the other side. They're all three on separate UVCHs.All on the same side and next to each other huh? Check the pigtail going to the that side of the head looking for damage/melting.
Yeah they do go bad. Think of them as 8 little hearts, one for each cylinder. Your heart mathematically only has so many beats in its lifetime before it gives up. Same with the fuel injectors. Like in our personal lives things will change how many times they beat. Air and water going through them, silt, bad oil, too much heat. I'd doubt there was a way of doing it at home. Injector builders use all kinds of fancy machines to test theirs before sending them out to the public. NAPA wants $560 for 1 rebuilt injector. F-that Beans Diesel sells one at a time for $125ea. (+ a $100 refundable core so there is no down time on the truck waiting for the injectors to come). Most would do just the three, I'd do them all to keep the mileage the same on all the parts and have all of them under warranty at the same time.I get the fuel filters free from work so I say why not you know. I got this truck in Nov. but I do think they are very old maybe even stock! I have no idea. Do they just go bad over time?........o sorry yes I did the screen clean two months agao and it was plugged solid. I should prolly do it again huh. If it might be the injectors is there any way to test fuel flow with out sending them in? If they are bad do you know where to get a good price on some?
The fuel filter cartridge and the Fuel Pressure Regulator Pre-Screen (Ford PN 9150)Which fuel filter screen are you reffering to? I've only changed my FF when it comes to fuel
