Hello everyone!
First. Post Ever!
I'm in the process of replacing my glow plugs, GPR, harness, and valve cover gaskets. I had one connector that was fried and thus needed to be replaced. The remaining connectors are all intact and seem to be functional.
I'm using DieselRX GP's.
The plug in question is the front driver side plug and after removing the factory tape I discovered what appears to be some sort of a ground shielding wire. Can this wire simply be re-wrapped about the replaced wires or can it be removed?
Also, does it matter if the new wires are slightly longer than the previous wires? I'm going to need a bit of room to solder and apply the heat shrink.
Additionally, it seems that one of the intake hoses is worn and should be replaced. Is the part below one that be purchased from an aftermarket supplier?
The hose still seals, as the tear is after the clamp, but I'd feel better replacing the part while it's all apart.
Thanks a bunch!
M.
First. Post Ever!
Thanks a bunch!
M.
