Drove my 96 F250 home from the transmission shop the other day after a rebuild. Ran fine for the 60 mile trip. Parked it in the driveway then went to start it yesterday and it cranks but will not start. No Wait To Start light and no white smoke out of the exhaust pipe. Had the issue with the fuel heater a few years ago. It would blow the fuse but at least the engine would start and run although it only ran on a few cylinders (The fuel heater wire is disconnected and taped). This won't start at all. I have a remote start and usually it delays until the WTS light goes off before it tries to start but when i used it yesterday it hit the starter almost as soon as i pressed the button. Tested the glow plug solenoid and it works just fine. Pulled and checked all the fuses under the hood and everything was good. I saw in some previous postings that there could be a problem with the PCM. Is this the same as the injector control module? Replaced that last year as it all of a sudden started running really rough and had no power. The injector control module fixed that issue. I know when i had issues before with a broken glow plug relay it would crank and blow white smoke but wouldn't start. No smoke out ot the pipe at all this time. Gave it a little sniff of ether and it starts and runs on the ether but dies. I only tried that because i knew the glow plugs were not working. I know not to use starting fluid on a diesel engine with glow plugs. Any help would be greatly appreciated
