I made the of getting a parts store rss. Put the 3rd one in know.
Where can I get one that doesn't go out in 2 months and my powerstroke likes?
Do u know a good place to get them. I try to avoid the dealership as much as I can.Get the Motorcraft ones they work the best from what I've seen.
Thank u. I ve been going to oriellyAdvanced auto has one listed, depends on if your nearby stores stock them but even if they don't they almost always have them at nearby hubs which takes about a day to get it depending on when you place the order
The Motorcraft sensor is ford certified thoughThey all suck. Ill only put ford sensors in. Check riffraff
It starts freaking out above 65. Jumping from 70 to 50 Then it get worse. Starts freaking out at 60. Then at 55."Going out" ? -- as in when you ohm test the sensor it shows open?
your speedometer quits working?
Is there physical damage to the magnet tip? or metal particles?
