Hi Guys.
I'm fighting with a 96 F350 7.3. Originally a no start issue that threw a code of P1283 = IPR circuit. I purchased a new pigtail for the IPR and put 12 volts to the IPR while cranking and the truck started but ran very rough. I then purchased a new aftermarket IPR and installed. Now all codes are gone but something is still wrong. Symptoms: Truck takes a long time to start, maybe 15 seconds after "wait to start" light goes off. When it does start, it idles nicely for about 8 seconds then gets very rough - rpm jumps up and down. "Check engine" light stays on. If I increase rpm just a bit, seems to smooth out, somewhat normal. If I let run for 1-2 minutes, idle seems to settle down a bit. When key is turned off and trunk is started again, the same issues re-occur. I have the pipes from the turbo to the valve covers removed, but the engine sounds loud to me. I also tried disconnecting the ICP while truck was running - no change. Truck only has 120K and well kept. It deserves better.
Can someone please help me?
Thanks,
Glenn
Thanks,
Glenn
