1 - 9 of 9 Posts
Hi I have a 95 7.3 5spd with ts6 chip and it died as I was driving one day went to restart and no wts light came on nothing from tachometer no fuel smoke nothing replaced idm and pcm still no wts light,no start(tryed without chip first then with) check and replaced all fuses under the hood got nothing also replaces valve cover gaskets,pig tails and glow plugs
Trucks been sitting really wanna drive it again please help 馃檪
1995 Ford F350 Dually
Why are you spending so much money when you don't know what's wrong with it? Need to first get a code reader so you can have a starting place instead of just guessing.
If condition was unknown of the replaced parts then it still didn't hurt to replace them.
I'd double check all the fuses with a multimeter.
The sudden dying can be caused by the fuel bowl heater grounding out or another electrical short.
You can get a bluetooth adapter and download Car Gauge Pro to an Android device and connect to the PCM that way.
A scanner is the best option at this point. Also verify the PCM was replaced with the correct unit.
Maybe check all your ground wires. One loose wire will kill the motor instantly and will probably affect the WTS light too.
1 - 9 of 9 Posts
