1 - 1 of 1 Posts
leaking into valley under pump only under hard acceleration, not at all normal driving. fuel traced down driver side of block with fan spraying to area with lines going to lift pump confusing leak source. in a short accel valley is already wet everywhere, but i understand there is a weep hole under the pump must be the leak source, going to slip a clean towel under pump to confirm, my question now is does the turbo pump have extra fueling at boost, the normally aspirated pumps wont have? then does anyone reseal their own pumps, or is it considered a reman replacement? and thanks for any advice!
1 - 1 of 1 Posts
