My new truck :grin: Just parking this thread here because I got a 6.0 to finish and a lot of other stuff to get done before I can give it much love and do a restoration thread, but someday,,,,
The truck has 180k miles, it's from SC for most of it's life which saved it, because it spent the last 6 years in Wildwood, NJ which if you've ever been there is one of the most corrosive places on earth. The floorboards are Flintstone style, the only thing between the cab and the road is the super thick mats they put in back then, but after that it's not unsavable. The outer rockers are ok, as are the doors and most of the cab, little in the usual places but mostly grindable, looks like only the lower fenders actually need cutting off.
The engine is the jewel. It's got 36k, was in a brand new international schoolbus that sat on a lot until it got scrapped, but not before somebody saved the motor. It is purrrdy. Got put in the truck in 2012 with 13 miles registered on it. I'll get pics soon as it gets delivered.
I bought this because I have a 6.0 that I'm rebuilding (I think the only other thread I started here), and it's not done and I need something to tow stuff with so I got this thing, and as much as I loved learning the 6.0 motor and doing the rebuild this thing just captivates me. It could not be simpler. The motor spins, the fuel pump arm flaps, pumps fuel to the injection pump, the pump spins and squirts fuel down the lines to the spring valve injectors that pop open when the pressure gets high enough. Literally, you connect the tank to the fuel pump and the throttle cable to the injection pump. No turbo, no fuel pump, no intercooler, no PCM, FICM, IPR, no nothing. One wire to turn it on and off and that's it. Mad max woulda killed for this thing, it will survive EMPs and will run on practically any greasy sh!t you pour in it.
Anyway, I digress. Pics to follow at some point :grin: :beer:
