1 - 20 of 361 Posts
We'll I finally found my dream truck and I'm getting back into a Ford. 1970 F250 crewcab, putting in a Cummins 4bt and a M5R2 5 speed tranny. I've been searching for one of these trucks for years and finally got a hold of one.
Few pics:
After about 60 hours of body work.
Old 360 coming out with NP435 4 speed tranny.
New to me Cummins 4bt.
Switching to Hydroboost.
New steering gear. Holy crap this things heavy.
The 327 I had built for her before I decided had to go with the Cummins.
My current Cummins which will be for sale when this is done.
Nice project man:thumb:
If it was me I would be stuffing a 7.3 in it though
Too heavy for these old Ford suspensions. Not made for 1000# + motors. I don't tow, haul anything, drag race or sled pull, this is my daily driver. I have a 6bt Cummins now and its way more power than I need.
New suspension goin in.
Mock up on a similar truck for the motor mounts.
4bt will be sweet if you turn it up enough.
Already tweaked it all 5 ways possible. Pretty simple pump really. Took me all of 2 hours to tune it. Can wait to get her running.
Cool project!!! Keep us updated.
Slacker
Damn, Dave! Really good looking truck. That looks like a fun project! :thumb:
Thanks Shawn, I'm having a blast with it. I can't wait to get home from work everyday and work on it. My wife isn't too excited about it but its better than the bus I built a few years ago that took up a lot more space.
Discussion Starter #12
Awesome build! I love those old crews. I'll definitely be following this build.
I may be sending a PM your way about your current CTD... :D
Pretty much just finished a year + of "restoring" that thing. Chrysler really knows how to build a cheap vehicle that wears faster than a pair of sneakers. I basically rebuilt the whole truck except the Cummins which purrs like a friggin kitten.
Heres the short list I've compiled of parts replaced:
New A/C components:
A/C COMPRESSOR
A/C DRYER
A/C EVAPORATOR (under dash)
A/C CONDENSOR
A/C HIGH & LOW PRESSURE LINES
Basically the entire a/c system has been replaced at a cost of over $2200.
Front end components:
New hubs
Ball joints x4
Shocks x4
Tie rods
Drag link
Track bar
track bar drop bracket
Coil springs + 5"
Dick Cepek long arms
BD steering stabilizer brace
New 3 turn lock to lock steering box
Borgenson steering shaft
Brakes x2
Upgraded to GM cylinders for the rear drum brakes (twice the stopping power)
New serpentine belt
New Goodyear tires 285/75/16r Road Armor E rated
New headlights
New 3rd gen tow mirrors
Engine upgrades and maintenance:
New VP44 injection pump
New AirDog 100 lift pump
New stage 4 Edge Jammer injectors
Quadzilla Adrenaline with Pulse in cab monitor/gauges. Beta 300 tunes.
BD RAD (eliminates torque management) switch controlled
4" turbo back exhaust
1 20" muffler
1 40/40 Aero Turbine muffler
Airbox removed for BHAF
Fumoto oil drain plug
Radiator flushed
Front & rear diffs fluid changed
Transmission:
Full rebuild with DTT (Diesel Transmission Technologies) internals
Triple disc torque convertor
Aftermarket valve body
Upgraded to GM solenoid ( higher line pressure)
New govenor pressure sensor
New tranny pan with plug
Rear main seal replaced
Transfer case flushed
Misc:
New door panels
new dash bezel
Pleather seat covers
Shell painted flat black with Thule racks
Carpet kit in bed with storage boxes
Quarter panels line-x'ed
New side steps
New flasher for blinkers
New front bumper
nice build me and my buddy r puttin a 6.0 in his ccsb 70 4x4 and its on 40's
Discussion Starter #15
I've seen a build like that on PSN and it came out awesome. Its so fun building a truck exactly the way you want it with the parts and drive train you want.
wana see the finished product
Very cool build. Cant wait to see it done.
Discussion Starter #18
Got her back on her own two feet again. New I beams, new kingpins, new coils, new control arms, shocks, bushings.....
40 years worth of crud gone. Old 360 should be coming out this week and hopefully 4bt going in. We got some work to do modifying the oil pan to fit around the drag link.
Gotta go her some new shoes this week too. Those old things are just nasty.
Runnin'wita2cylhandycap
This is going to be plenty cool.
Love the 4 door truck from the era.
You wouldn't happen to be able to read the number on the fan hub mount casting wouldja?
I've been looking for the lower style, 4 bolt direct drive hub for awhile. I noticed it has a clutch bolted to it but alls I need is the hub assembly number bolted on the block.
I'll bet the thing gets 20+ mpg when finished:thumb:
Discussion Starter #20
PM sent your way Big doofus.
The 360 is out.
Cabs' coming off this week to fix some rusted out body mounts and all new urethane bushings goin in.
Anybody want a 360 and NP435 tranny. Its a great rock crawling tranny.
1 - 20 of 361 Posts
