1 - 11 of 11 Posts
Ok im going to install the 17* hpop on my ealry 99. How hard is this? Im a little confused about it what exactly do I have to take off. Someone told me that I dont have to remove the fuel bowl
I did mine not to long ago. It is not to hard of a job if you have some mechanical ability. Took me about 2 hours. Bring it down to Texas and I will give you a hand!!!!
Go to dieselsite and they have some good directions that you can download and really help you out.
Got it in my brother broke the part on the fuel bowl so we have to go to international tomorrow and hope they have it
Thats good glad you got it in. What pump did you go with?
Just a used 17* off a 2000 with 96k on it. Mines an early 99 so I have the 15*
let me know if you notice any differance:thumb:
Time for the fuel bowl delete!!! What part did you break... those fuel bowls are expensive to replace!!
Discussion Starter #8 (Edited)
Absolutely
Broke the part on the top driver side right here. My brother over tightened it and it snapped. So if we can find the part hes gotta cut the fuel line and reflare it. Im sure international can get it but they arent open till tuesday
i broke the same fitting when i upgraded my hpop. ford actually had it that time.
Yea the Ford dealers here dont usually stock 7.3 parts. Dont need them much. Did it come just the fitting or with the nut and everything? Otherwise I gotta go the menards too...
it just comes with the cap. i got lucky and got the broken end out of the fuel line with a flat head and some luck. what when you remove the cap off the fuel filter, there is a spring in there. diesel site sell an upgrade spring that is supposed to raise the fuel pressure. i did it on mine, but i still have another issue with low power. i was hoping it was a weak spring, but for $20, i really wasnt worried about it.
1 - 11 of 11 Posts
