Looking for a little input or guidance. Maybe someone can tag me in a similar forum if one has already been posted. (New to forums so I apologize in advance.)
Truck Info - 2014 6.7l CCLB SRW - Only mod is DPF/EGR Delete and runs on stock tune.
400 Miles from home, 80 MPH on the interstate, no load
I got a check engine light and display on the dash something similar to "EXHAUST TEMPERATURE HIGH SERVICE IMMEDIATELY".
Series of events over the next 120 seconds:
-Opened up EZLYNK and already had fuel parameters on gauges.
The actual rail pressure was roughly half of the desired so I started to exit the interstate.
-As soon as I get to around 20MPH the truck dies.
-I coast to a parking spot and open the door and smell strong diesel. I look under the truck and near the driver side fuel is dripping from all over the front axle and area where the front driveshaft connects.
-I inspect the fuel rails and find the driver side rail has a significant amount on the front half.
CODES: P228E - PCM-Fuel Pressure Regulator A Exceeded Learning Limits - Too Low
P0087 - PCM-Fuel Rail / System Pressure - Too Low Bank 1
Out of curiousity I attempt to crank the engine.
Actual Rail Pressure goes to roughly 1,000 PSI
When I cycled the key a few times into the ON position, I did notice what sounded like a possible hissing near the left fuel rail.
I did no further trouble shooting as I was minutes away from a job site and its my last day of a long haul work trip. Just trying to get home and see my family!
Has anyone experienced anything similar (the large fuel leak along with cp4 failure symptoms)?
The truck is being towed the next 400 miles and will be dropping off at my house.
-Thanks in advance! Any input is greatly appreciated. If anyone is interested, I will continue to update this post with pictures and details.
