I have done some reading/searching and I can't seem to find a solution. Is there really no solution?
Has anyone successfully installed a 2011+ Ford Super Duty rear axle into an 2010 or earlier truck and gotten the rear ABS to function and found a way to have a functioning speedometer?
99-10 it seems have a tone ring attached to the ring gear. It's my understanding this tone ring provides the signal for speedo and rear ABS. The 11+ apparently have tone rings at each wheel for the 4 wheel ABS.
My truck, 99.5, only has rear ABS if that changes anything.
If you are wondering why someone would want an 11+ axle: Available with a selectable locker. Larger brakes. Correct width to match an 05+ front coil conversion.
TIA for any guidance.
