1 - 20 of 21 Posts
Does a tailgate off an 08+ superduty fit my 2000 F250? I replaced my mirrors with 08's and just had to slightly modify them but fit perfect.
driver side.
Not to be the search nazi, cause I really hate that chit when others say it :wink[3]:
I have posted the driver's part number in a previous thread. It is a simple bolt on.
You don't need the hinge if you remove the torsion rod on the '08 and up tail gate.
Shawn
I just did this job and the t-50 torx bolts are installed with locktite. I was swapping between two trucks, so I had double the work.
They were a bear to get out. I worked them back and forth with some pb blaster but heat would have helped a lot.
I have heard prices vary if you have the step included or not. 250-500 bucks from what I have seen.
Scott
Will the latch assy out of my 2000 work with the 2008 and up tailgates and the square 2008 handle? also will the top plastic molding from the 2000 work or do I need to get a 2008 and up molding, Thanks for any info....
no won't fit,
but i seen some f150 guys using them...
guess they get all the good parts :rofl::rofl::rofl:
Wait... it won't fit?
No it definitely fits...you just have to get the correct hinge. Not really sure what he's trying to say.
a joke...... there have been a ton of threads on here about the 08+ tailgate and how to swap them ....:nod:
and if anyone know anything about the 97-03 f150s they use the same tailgate as a superduty from 99-07
Administrator
I even read it twice... figured you snuck some hooch into the igloo
I see that f150 has 08+ tail lights too.
Also from what I've heard, if you don't have the lower assist. You don't need to change the hinge. This I just what I've heard and have no first hand experience.
I might go home and see if my 2014 tail gate goes on to my 2001
1 - 20 of 21 Posts
