I ve seen some 03-07 sd 's with the 08 mirrorson them is it direct bolt on or do you have to do some mods?do they use the same switch?
They are direct bolt on...all you have to do is sand down a plastic alignment clip. The same switch can be used, but the directions will be reversed because of the way the 08's are wired. They work great though...but there's an easy fix to it.
do the 08 power fold in will that work with the orig switch? i'll check ou steath thanks
Not sure. i know it will work but im not positive on the connections. Im pretty sure they bolt on real easy.
I wish they werent $450! damn. cause i REALLY want some. but 450 is half of a lift...
