1 - 7 of 7 Posts
Diesel Freak
put it in the search box ive seen it before put theres some serious cutting and fab work involved and the badges arent cheap at all
I have found that they are not cheap, but as for fab work I was going to trim any tabs off the emblems and mount them on the fender, not going to be functional vents.
WWW.COMPIGNTECH.COM
I have then on mine. If you get the 2008 versions they are fully functioning vents and the fenders need cut for them. If you get the 2009-2010 versions they are non functioning emblems. The 2009-2010 don't require cutting of the fender they are simply stick on's. I have the '08 versions on mine.
I plan on doing a set from '05-'07 when it's all said and done
1 - 7 of 7 Posts
