1 - 20 of 52 Posts
Need 2008 F-250 PowerStroke Wiring & Color Codes
Can someone tell me where I can get the Wiring Diagram & Color Codes for the New 2008 F-250 PowerStroke? I am trying to install a Remote Starter and Alarm System and I am hung up on the Power Door Locks and Dome Light circuits.
Thanks,
LC
At this time I'm thinking you will have to get it from a dealer, Probably nothing around yet other than that.
Gord.
I have PDF of Electrical Diagram 2008 f250 diesel
All,
I have attached a Zip file with some of the necessary images regarding the electrical system
08 Superduty diesel (some gas are the same see schematic)
All Door Windows
All Sunroof
All Anti Theft
All Keyless remote
All Interior lighting
All Parking turn signal lights etc..
All Power Door Locks
All Starting system
All Audio systems
All NAV Systems
All Upfitter Relay schematics (just re-download the zip file)
***Updated*** Added 03.06.08
1: Installers cheat sheet for elecronics by Audiovox (a real helper)
1: Pic of Tach wire and location Added 03.06.08
*** Updated *** Added 03.06.08 (7:30pm est)
1: DEI/DirectD Installers Cheatsheet (Better then the Audiovox one imho)
*** updates to come as needed ***
I will keep adding to this file
as several dozen files to screencapture
contact me if their is something specific
Ive got the whole superduty lineup for 08 on file.
Regards -=Sam
BTW file is here
hmmm upload failed... tried 2 diff browsers.
go here...
http://www.hyperlinks.net/superduty/08F250DieselWiring.zip
I too own a '08 F-250 Diesel
I have the factory ford CD with all diagrams.
feel free to contact me regarding this info
I can either post here or email to you.
-=Sam
All of these are in the drivers door sill and kick panel area:
blue with green stripe (grounds when you hit lock button
yellow with white stripe (grounds when you hit unlock on the door switch)
In the harness that comes from behind the driver's seat fron the b pillar:
violet wire (shows +12 when you turn on dome light or open door)
Here's what I used to install my remote starter.
MODEL YEAR(S)
F SERIES SUPER DUTY 2008
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
bulldogsecurity.com
just hit the wiring diagrams button and select the car
Steering Column Wiring
I have looked everywhere and cannot find out whether I can add the radio controls to my steering wheel since it did not come standard? Any idea if the harness is there?
All,
All Door Windows
All Sunroof
All Anti Theft
All Keyless remote
All Starting system
All Audio systems
All NAV Systems
Regards -=Sam
BTW file is here
go here...
-=Sam
wait to start
How come all the wiring diagrams ive found do not list the wait to start wire location my add on remote start does not have a built in timer and needs to be connected to wait to start to work
wire diagrams for 2009 Ford F 350 Super Duty?
Hey Sam,
Thanks for the files. Can you get wire diagrams for 2009 Ford F 350 Super Duty? Or is 2008 wires same as 2009?
Albert
All,
All Door Windows
All Sunroof
All Anti Theft
All Keyless remote
All Starting system
All Audio systems
All NAV Systems
Regards -=Sam
BTW file is here
go here...
-=Sam
Is there another link. It does not seem to be working anymore.
Thanks:D Would you happen to have the pin-outs for the the power lock switch?:please::please: My 2009 door panels just came in and I am going to try to start getting all the wiring set up for my 2002:thumb:
could you be a little more specific?
I am putting door panels w/ OEM switches from a 2009 FX4 (not sure 250 or350) into my 2002 F350 XLT. I think I have the power mirror fold/telescope switches figured out as well as the power windows, but I can not find a pin out for the plug that goes into the the bottom of the power door lock switches (driver, passenger side) in the 2009 panels.
1 - 20 of 52 Posts
