1 - 9 of 9 Posts
My question is will it fit. And is it the cheapest route to go 4-linking my truck?
Sent from my Droid using AutoGuide App
I don't know if there is a cheap route. You probably should swap out the axles to the 05+. That way you have something to attach the links too and you could buy a 4-link kit. Or you build some serious brackets to mount your links too.
I don't think there really is a "cheap" route.
I thought the 05 was just like out. What do they have?
It is a radius arm with a coil spring.
I was looking at the 08 the other day with lifts on them and it just looks like all the components just bolt either onto the frame or bolt onto the axle so I figured it wouldn't be too hard. Some one had to have done this before.
If you had the newer axles you could probably do just that. Do a little searching and I would bet there is an old thread about it.
Roughly what is the cost on something like that?
1 - 9 of 9 Posts
