This truck will run pretty until the engine warms up (not Hot) the just quits no sputter or anything. When you try to start it again right away it has no electrical power under hood.(no fuel pump. starter wont turn) But it has electrical power in cab. Let it sit a while then it will crank and run pretty til it warms up again. Longer you let it set the longer it will run. Cant really figure how search for this issue. May be a common problem, I just dont know enough about it.
