1 - 1 of 1 Posts
I have a 2006 Lark 7x14 enclosed trailer for sale, tandem axle, 2 brand new tires ...trailer is located in mineral wells texas but for a serious buyer I will drive up there and bring it down to houston where I live.
6 inch I-Beam steel frame construction
- Precision, jig-built, side
- Formed steel rear header door with a bar lock and premium
- Double rear swing doors with semi- strap hinges.
style cam locks and T-nuts. - Automotive-style weather stripping
- Tandem Leaf spring Axles with elect. brakes - 5-bolt white spoke wheels with 15
- Aluminum “jeep style” fenders inch bias tires.
- Aerodynamic front fiberglass cap - Galvalume roof design
- 3/8 plywood interior wall construction - 3/4 plywood floor construction
- 16 inch on-center side walls - 32 inch side door
- E Z lube hubs - Flat roof with rounded corners
- 2 5/16 inch coupler & 2000lb Atwood jack - Frame undercoating with Z-Tech
- Exposed metal is painted with premium - Bolted or welded-on safety chains
quality black paint - Premium semi-trailer quality
- Full DOT lighting exterior lighting
- Strong premium all-steel welded - Long life coating on fasteners
frame - 5 year quick and easy limited
- High-tech roof sealant trailer warranty
- Screwed aluminum exterior - 24” inch on center in floor & roof
Color- Grey - 7 Way Bargman plug with break away kit.
- Interior Height 72 inches - Aerodynamic front end design
$3800
CALL MIKE at 817 914 5062
1 - 1 of 1 Posts
