I have a 06 f350 dump truck, suddenly while driving I lost boost and could only do 50 mph. I had a egr low flow code. Replaced egr code gone. Truck has 63k I have owned it from 52k. Egr cooler & oil cooler were replaced 3k ago. Volts are good & no leaking noises everything seems tight.
Any ideas
Check the boots on the cac tubes and the tubes for splits or loose clamps.
Check the firewall for soot you may have a split or loose clamp on the exhaust up pipes or flexes.
