1 - 8 of 8 Posts
05 f350 ebs reading 60 to 185psi while plugged in to sensor weather its in the pipe or the atmasphere but when its unplugged it goes to 20psi new sensor and cleaned pipe think its maybe a short ?
I had to replace the EBPS pigtail when I replaced the sensor and sample tube.
Alliant ICP/EBP Sensor Connector Pigtail AP0021
The harness pins were corroded and loose. If the pigtail passes visual inspection and you have no continuity between each pin nor ground and positive/output leads then you need to follow the harness back until you find a clue.
how can i check that to see if thats the problem
...look at the connector for failure and test each pin with a multimeter?
Sinister Diesel Sucks!!!
What are you using to watch your EBP reading? My Insight CS doesnt recognize any readings. My SCT X4 does recognize the readings and they are similiar to yours but I have no run issues. These numbers are way out of range for the sensor so it doesnt make any sense. My research has turned up that there is a calculation problem in the monitor making it an unreliable reading. When was last time your ECM strategy was updated by a dealership. The latest strategies dont use the EBP sensor, it is inferred from MAP & MAF readings
1 - 8 of 8 Posts
