1 - 17 of 17 Posts
In very good to excellent condition with mounting brackets. $115 Shipped to your door
will this fit an 05 that currently doesnt have this radio in it? Same connector as the normal non 6 disc radio?
If you have the same big connector as in the picture then it will work, best to check with your dealer but I'm 99.9 percent sure that it will fit and work. It came out of an 05 F250 SD CC FX4.
Hey F450 DRW, how does the aux work? I have an loaded to the gills 05 and wondering how the Aux works. Did you have this in your truck?
Will work with factory external 6 disc changers or after-market iPod patch cables. Push the Aux button to access whatever is hooked up to the connector.
where is the "Aux" connector? I don't mean to hijack this thread but i've got the Aux button on mine and would really like to hook up my iPhone to listen to pandora while i'm driving lol.
Discussion Starter · #8 ·
Smaller plug on the back of the radio
is it on the harness? i don't see it on the pictures you've posted.
Discussion Starter · #10 ·
You need an after-market adapter to plug into the back of the radio and it has a cable for your iPod or whatever.
will it fit 03?
Discussion Starter · #13 ·
If your're good with a dremel. Fits 05 through 07
will this fit an 99 double din hole?
Discussion Starter · #15 ·
99 is din and 1/2 not double din, won't fit the plug or the hole :icon_ford:
Ithought mine was DD because I have the Ford Premium CD and tape player, its a big hole!
Thanks though
Discussion Starter · #17 ·
Radio face roughly measures 4 3/4 by 7 3/8 inches
1 - 17 of 17 Posts
