1 - 5 of 5 Posts
I have a 05 6.0 and the other day she just doesnt want to start!! i have just let her sit for a week and just went to try her and she put up a tbc code on the dash.. The injectors were getting worse but she was running fine the day b4 any ideas please let me no
thanks
Josh
The TBC fault is just from extended cranking. You need to get a scantool on that thing first
+1 on the scan tool, If you can get it to start and don't find any problems with the scan tool I would try running an additive to clean the injectors. You also need to check your ficm voltage and make sure it's above 45v anything below that you have a problem with your ficm and will need to have it replaced or rebuilt. As far as an additive goes I highly recommend getting a friction modifier for your oil look for something called archoil 9100 and also get a bottle of there 6200 for your fuel.
Sampson means 46 volts :) also make sure when you test the film, it doesn't fall below 46 during the buzz test, cranking or running. Should be 46-48
1 - 5 of 5 Posts
