1 - 10 of 10 Posts
234k+ mi, EGR delete done at dealership when bought new, not studded.
Truck had started to become a long crank slowly getting worse for about 2 weeks. Then I didn’t start anymore.
I have (after no start) replaced
Oil/filter, fuel filters and a blue spring kit, stand pipes/dummy plugs, STC fitting,ICP, IPR checked cleaned( no screen damage or debris).
Any advice on my next step would be welcomeed:(
Your cranking speed is too low and so are your vehicle volts.
Charge and individually load test the batteries.
Thank you for the reply. The batteries where done just as you suggested. I had been doing cranking intervals to get early readings then moved to checking connections. I failed to record the data till I was about done.
The Volts never showed on the ficm main above 10.5,
I did a pin test KOEO prior to this and had 48v.
Are the batteries really going to cause all the codes?
They could. You also will never get a start if the cranking rpms are below 150. If it isn't your batteries, then it is likely to be your starter. Load testing batteries is free .........
A simple voltage check means nothing. A battery can read 13 volts and then drop to zero w/ a load.
Battery cable connections(check both ends) -- one or both batteries bad
Quick and dirty load test can be done by removing the driver side battery -- crank with head lights on and observe the voltage(brightness of the lights is also an indicator)
Swap in the removed battery into the passenger side and re-test
If the battery/starter/cables are fine, the engine will crank with only one battery
Thanks guys. The batteries were fully charged and a load test was done previously before the scans.
My wording was possibly not apparent enough in my 3rd post. Apologies for that.
I have a Snap on MT3750 AVP that I did the load test on. Volts never dropped below a 9.6 on a 15 second load test. 650 amps showing on both 810 cca batteries.
Battery voltage below 9.5V will cause delayed/hard starts. You are pretty close to that and maybe you are dropping below that but your update frequency isn't showing it.
FICM Vehicle Power (Volts) (Should be 12+ Volts, should never drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03
As posted above, if you aren't getting 150 rpm cranking, it won't start. That is the focus are IMO.
I Appreciate your input, it was getting above 150 rpm when I started checking things out. As mentioned I didn’t record any info until I had been trying different things for about an hour(ie watching the scanner, and having someone else crank it over while I was checking connections.)
So the batteries were low when I remembered to record the data.
I have a different (known working) FICM on its way.
I will have it Tuesday.
Again thank you for your help.
Good deal. Please keep us informed!
1 - 10 of 10 Posts
