Got a chance today to run through G8orFord and djmaguire suggested. Pulled IPC connector and cranked the engine. Below are the Torque Pro numbers and Fault Codes with the IPC connector pulled:
FMP ICP (HPOP) ICP Volts FICM Sync IPR %
Key on, cranking 48.5 1598.3 0.0 1.0 71
Fault Codes: P2285 - Powertrain, Injector Control Sensor Circuit Low (expected since IPC not connected)
P0270 - Powertrain, Cylinder 4 Injector Circuit Low
Grey Codes: B1360 - Body
P0261 - Powertrain, Injector Control Sensor Circuit Low
P1000 - Powertrain
P2617 - Powertrain, Grankshaft Position Signal Output Circuit/Open
U1900 - Network
Torque Pro and Fault Codes after reconnecting IPC and cranking:
Key on, cranking 48.5 155 - 560 0.8 1.0 83.9
Fault Codes: P0261 - Powertrain, Cylinder 1 Injector Circuit Low
P1000 - Powertrain
U1900 - Network
The ICP connector was clean and no oil found in the ICP connector. Found no chaffing of the ICP black wire wrap, no connector cracks and no wires looked damaged. Visual inspection shows no wiring issues. LPOP builds to just about normal after long crank.
I'll pick up tools needed to check for air leaks. Have seen two methods: checking each side separately or checking system via removing IPR and connecting air adapter to where the IPR goes. Any recommendations on which to process to use?
