I didn't want to hi-jack anybody's thread on headlights for the 05 - 07 front ends. :nod: After looking at HD headlights I ran across these folks at The Retrofit Source. A true HID seller and has what looks to be a very nice setup that would work fine in the 05 - 07 setup.
Has any Forum member done this mod yet with the FX-R Stage III kit into a 05 headlight package? You have to heat the OEM headlight assembly in an oven to get the silicone sealant around the 2 plastic pieces (black base/clear lens) seperated. Then you can mount the projector unit into the OEM headlight assembly. Low/high beam setup with the 1 bulb and another HB lamp can be added if you want. Should light up the road if you happen to be in BFE land at night.
Bi-xenon FX-R Stage III Kit - Complete Retrofit Kits from The Retrofit Source Inc
