1 - 2 of 2 Posts
did an egr cooler,valve and engine oil cooler in this truck got running went for a drive and it died like you shut off key. had ford scan it and they said it has low high pressure oil. how can i check without scanner or guage. also would the ipr valve have something to do with this?
I just did my EGR cooler, valve and oil cooler last weekend and had the same problem. Tech scanned it and said it had low high oil pressure. He tore it down today and found that the oil pressure regulator came apart and the parts went into the HPOP and trashed it. Getting new HPOP, STC and regulator as well as any seals that may be bad. Also found that the head gaskets were blown in 3 spots. Putting in ARP studs and head gaskets as well. I just want my truck back!!!
1 - 2 of 2 Posts
