allright i have a 2004 6.0 f350 dually. trucks idles like its got a cam in it. kinda sounds like the bad fuel videos i have seen on youtube. but the truck also shakes a bit while im driving it and the tranny shifts into overdrive. i replaced the filters and put some diesel kleen in the tank. but it still does it. im stumped!!!!! please help!!!! and i have no codes bein thrown....
if the injectors where goin out the truck would smoke wouldnt it??
Just got my truck back from the dealer. Sounds like the problem i had. The mechanic told me that some codes wont throw a check engine light. I had bad #6 injector and a water in fuel malfunction which was also causing a MAP sensor malfunction. There is a TSB for the Water in fuel Malfunction it is TSB 6-22-12. Hope this helps.
