you turn the key and it'll crank and crank, lift pumps has no power, injectors don't fire. even trying a hot wire strait to the pump, but it still isn't firing the injectors. no codes on the ecu.
some times you can slowly turn the key and the fuse box will chatter a way but not stay on. then out of the blue (or after 20 minutes of cycling the key) it'll start and run 30 seconds. cycle the key a few more times and it'll run, just don't turn it off.
where would you start, ignition switch? id think you'd start there, but way would everything have power but not fire? :doh:
i'm lost.
i'm lost.
