1 - 14 of 14 Posts
What would cause a turbo that is producing great boost (25 @ 6000') dosnt seem to have any leaks but, it just dosnt sound as loud as when I first installed it. Ecspecially at idle. Is this possible? What would cause this?
Maybe you are getting used to it? maybe load the stock tune and switch back?
I might be...truck not tuned yet
old age = loss of hearing
I wont argue that Im getting old... but the turbo at idle just dosnt sing like it did.
Maybe the vanes are stuck so it's not cycling while idling. Mine will cycle between 15% and 85% most of the time and sometimes it will just sit at 67% and be happy there.
The turbo could be stuck in the perfect spot. Believe me, it happens. I recently cleaned a turbo in a 6-speed truck that definitely had a negative affect on performance. It's really hard to explain to a customer that their truck runs worse now after I "fixed" it.
The whistle at idle is caused by the vanes being all the way closed creating the most backpressure and it needs the highest VGT duty cycle to do that.
I think my hearing got a little worse too because im getting proper vgt% and it just doesnt seem as loud anymore haha no one else thinks that though :hehe:
Ok if I remember correctly I saw the vgt% on my Edge CTS. What should it read?
It may read between 60-85% at idle. When it reads high the PCM is trying to warm the vehicle up faster.
I definitely noticed my 03 turbo wasn't much louder at idle than my 06, it was off idle that the thing started screaming. Eventually I did get used to the the 03 and it lost its appeal.
Discussion Starter #12
Okay at start up with engine somewhat warmed up it went to 85% very quickly. Then after warming up a bit and while reving it up it would drop to 35%.
seems normal. I'll check my vgt readings tomorrow. what are you getting for a WOT boost psi? and is it tuned or not when you do the wot boost measurement.
Discussion Starter #14
Only "tune" I have is the atlas 40. I saw readings around 30% revin it up in the driveway. Dont know if I need to be actully running down the road and do a WOT.
1 - 14 of 14 Posts
