1 - 7 of 7 Posts
Want to put on the new turbo oil feed tube. I need to replace my oil cooler cover to do this. Will a cover from an 05 or newer fit?:dunno:
Looking at the new line and oil drain tube on ebay. Guy says icp sensor has to be on right side valve cover. Don't understand why??:dunno:
The oil cooler design did not change. The one and only change between the years is the mounting of the turbo oil supply line. He says that so that someone buying the new style cover to put on an early 03 engine knows that it won't fit, due to the way that the turbo oil supply line attaches. Since you will be updating that part at the same time, it is what you want.
1 - 7 of 7 Posts
