The bolt pattern is the same, so it will fit... but because it has a crossover in the rear, that will interfere with the '04.5-'07 turbo pedestal.
If your plans are to have the intake modified/ported and intend to remove the crossover then yes it will work.
If the EGR cooler is intact then won't you need to change that too? The round one on the 03s is shorter than the square one on later models.
Yes that is correct, I forget that not everyone does the EGR delete.
