ok i have an 03 f250 it already has an 8" lift on it but i was tryin to get a little more height to it. has anybody got a setup with the 8" lift and 3.5 or 4" hanger lift? good or bad? and if it is good where can i get on and made all do i need to get it to work with my existing lift kit?? thanks im tryin to clear 40's
You'll need cross over steering, longer or adj. track bar, longer brake lines & longer sway bar end links. probably need to lengthen both front and rear drive shaft. Not sure if you would need to modify rear E-brake line.
You should check out Precision Metal Fab. He has a killer price on the crossover steering and solid looking hanger kits. I'm sure he could set you up with every thing you need.
ok thanks ill check it out
