Hello all,
I have an 03 that has been running fine until I went to crank yesterday. I put a new exhaust system on and a boost and pyro gauge, went to crank to check for leaks and spins but no start. I have checked HPOP and I have oil, I have voltage across GPR and I checked fuses. Replaced CPS just because I keep spare but that didn't fix. Everything looks good under hood, I unplugged ICP and that didn't work either. Have 2 good charged batteries. When cranking oil pressure moves but I thought the RPM should move too, correct? I get a WTS light and I can hear the GPR engage and shut off. Have good fuel pressure and clean bowl and filter.
I am usually pretty good with troubleshooting but I am at a loss here as it was running fine last week and all I did was install exhaust and 2 gauges. The inside cab install is not complete yet but the under hood connections are complete. The 2 gauges are Banks as well as the exhaust.
