I wish feel ya, I'm having he same porblem:doh: Pretty soon I'm gonna fix that sticking injector the fun way:hehe: Its called SCT custom tunes. Best of luck to you.
have you had your truck re-flashed with the newest flash ......mine did the same i would start in the morning and it would sound like bowling balls in there and i would have no power untill it wormed up ......but i got it flashed at the dealer and its great nowCranks/Starts good, feels like one or more cylinders gone. Cycling key (longer glow plug time) no change. No codes present. Replaced driver side glow plugs. No change. At normal operating temp. runs great, lots of power. Have factory manuels but not much info on driveability if no codes present. Problem only exsists when sitting for more than ~8hrs regaurdless of outside temp. Where should I test next, or is this a common issue? Thanks. Keith.
