Have a 03 6.0 blowing white smoke. It hard starts, has absolutely no power in between 0 to about 1500 rpm (I could floor it and it won't move), rough idle, and gets about 8 mpg. This is all whether it's warmed up or not. Now it's started stalling once it's warmed up and then wont start again for about a day(I think maybe caused by a high pressure oil leak somewhere).
We are about to pull the engine to see what damage has been done. While we are in there I will be installing:
APR Headstuds
PMM EGR Cooler
Black Onyx Head Gaskets
PMM Coolant Filtration System
New Engine Oil Cooler
Fuel pressure regulator upgrade kit (Blue Spring)
Cleaning EGR Valve and new Gasket Set
Possibly new injectos depending on their condition
Upgraded Turbo Oil Drain Tube
Maybe a HPOP
and fixing any damage that may have been caused (thinking it may have a burnt piston)
My Question is:
What else should I look to replace while I'm doing this to be absolutely sure it won't have anymore issues?
Thanks!
APR Headstuds
PMM EGR Cooler
Maybe a HPOP
My Question is:
Thanks!
