1 - 20 of 38 Posts
Speedo is stuck at zero, odometer isn't tracking movement, only displays last known mileage. No other faulty indications, codes, or red flags. This signal comes from the sensor on the rear diff correct?
Any way to test the sensor? I can shoot the wiring I suppose if I can pull a schematic. I'd feel better if I could pinpoint the problem so I don't have to shotgun a new cluster or send it off for testing/rework.
Try replacing the speed sensor on the rear axle.
IF it is the rear axle sensor, there should also be an ABS light, no cruise control, P0500 in the ECM, and if an automatic a flashing Overdrive light. If only the speedo and odometer are not functioning, I would lean towards the cluster. You can check the sensor for resistance. When mine failed, it was reading meghoms. The new one was about 2,000 Ohms.
I tend to agree with dave's assessment even though 2k ohms is awfully high for a sensor but if it's within specs then it's fine. You can jumper the connector and bypass the sensor to see if it changes anything but if it's only the speedo and mileage that crapped out Id think they have a shared power wire. I'd look for a broken wire or a corroded one but bypass the sensor first before wire chasing
Sent from my iPad using Tapatalk
No ABS light, Cruise inop, haven't tried pulling codes but don't have any other lights indicating a failure. I'll have to grab my code reader out of my other truck and see. Truck seems to just think it's not moving. It is a 6spd so I don't have the flashing OD light.
Not sure what bypassing the sensor is going to do since the sensor is what gives the signal... not knocking what you are saying but...
Does anybody have the FSM schematic via PDF?
I'll pull and ohm out the sensor for kicks, try to pull codes, and see what I get.
****EDIT: Just pulled and ohmed out the sensor, shows 1.95Kohms so I can rule that out.****
Still trying to figure out what works and what doesn't.
So far I've found:
-Fuel gauge on the fritz, reads intermittently: sometimes good, some times buried and turns on the fuel light.
-4x4 light inop, it's locking in fine.
So far I've found:
There's a shorted wire somewhere. Something is chaffing severely. Find where all the systems wiring is routed together and you should find some exposed wiring. If your fuel qty gets worse on bumpy roads it's a short.
I've certainly checked a few thousand sensors of many different types over the years. 2K for an inductive pickup like the rear axle sensor or a wheel speed sensor is typical. How many "sensors" have YOU actually checked?
Hmmm. I said 2,000 ohms, and the guy found that his is 1950 Ohms. I have a better memory than I thought. Or maybe I just know what I'm talking about, having been doing this stuff for over 50 years.
If the OP does NOT have Trouble Code P0500 in the ECM/PCM, the rear axle sensor is working, and wiring is intact at least to the ABS module (which conditions the raw sensor signal) and then to the PCM. The speed signal wire into the cluster is gry/blk. It can be checked for A.C. voltage with the rear wheels turning to see if the signal is getting to the cluster. But I suspect you have cluster issues. You aren't the first guy with a 2001 with these problems. My observations on here lead me to suspect the cluster.
Bunch of nonsense.
Bunch of nonsense.
Thanks DaveP, that's good info. I agree with you. Just wanted to ensure a couple of things before I go and shotgun an instrument cluster when I'm footing the bill lol!
deezntuz- The fuel issue is separate. I'm certain it's in the tank. As far as the 4x4 light, it's probably just that; a light.
Bunch of nonsense.
Are you an electrician or auto mechanic. A sensor is the same as a switch it just activates and gives a ground at a specified condition. It could be temperature, pressure or a wide variety of other things. Whatever its threshold for failure (i.e.- It's resistance) allows it to give the power signal that sits at the sensor a ground which is all power ever looks for. Just as with combustion you need 3 things for a circuit. You obviously know the 3 combustion needs with all your experience but tell me what an electrical circuit requires to function and I'm only talking basics. If you understand what source,load and ground is its simple. If it's only a sensor than when it reaches its operation limit which is agreed to be around 2k then it completes the circuit resulting in a light. A wire that has exposed center conductor before the sensor which I agree is good will cause a failure light since it doesn't need the sensor for a ground. I only have 13 years as an aircraft electrician but wiring and sensors all operate on the same principle. Experience is only applicable if you know the P.O.O's. We're seat belts even installed mandatorily 50 years ago? Nonsense is you telling someone to put a vehicle in the air and check for voltage with the wheels turning. Your path of troubleshooting tells me you understand basic electrical operation only enough to read a dmm. If it has a light it has power which is why an electrician would start by ohming out the wires just be sure to pull the associated fuse or it will read to ground through the fuse. It's shorted to ground between the source and load and bypassing the sensor. Snarky comments annoy me thus the extensive explanation of electrical theory. Oh and I've likely troubleshot more types of sensors than you could even identify as a sensor sir. Aircraft are a bit more complicated than vehicles.
#1, you're full of crap regarding the rear diff sensor. You don't have a clue as to how it functions or how it sends the speed signal. There is NO voltage on either wire if checked to ground. The sensor is a permanent magnet with a coil wrapped around it. As the differential tone wheel passes by the sensor an Alternating Current voltage is produced in the windings of the sensor. This signal is processed by the ABS module.
#2, you've been a member here 2 weeks with 45 posts, most of them useless as evidenced by a ZERO "thanks" count. Stop attempting to impress peeps that know more than you do with what you DON'T know. You act like a 12 year old troll attempting to post drivel in any thread you can think of something to write, regardless of accuracy or helpfulness. I saw in a post you're an "aviation electrician". My gawd, I hope you work on GA stuff because I wouldn't want to fly on any ATP or 141 equipment you've worked on. My guess is you work for a municipal or LEO flight department. Hiring standards are pretty low for those posts, and they can't fire anyone for incompetence.
#3, your on my ignore list. Your junk isn't worth the distraction of seeing it. Good luck here.
Discussion Starter #11 (Edited)
I'm an aircraft electrician too, heavy helicopters 16 years, & I know my way around with a meter. I don't do much troubleshooting anymore as I run a maintenance department but I've still got mad skills lol. Not all sensors are switches. This one works like a mag pickup from what I can tell... maybe not a 100%, but where the ring passing the sensor sets up a mag field (back to the basics of E & H lines) inducing AC voltage that goes down line to the ABS Module & instrument cluster. The sensor is an output device, not a switch for a ground. I didn't say it earlier but since there's a pissing match about who knows WTF they're talking about; deeznuts, bypassing the sensor would be retarded. To check the sensor, you could statically ohm it out or duplicate the input (mechanical motion) and read the output (checking for A/C) on the other end.
@DaveP. (thanks brother) gave me the info I need to get started since I have come up with jack-diddly-squat trying to find schematics or an FSM online... seems Ford has gotten stingy with their tech info. I just need to find the time to unplug the cluster and check there before I go pull and replace parts.
Discussion Starter #12
I'll probably throw the back end up on jack stands, put it in Neutral, key on, and have my kids go full on hamster wheel with the back tires and see if I read anything at the plug. Be funny to watch them and give them something to do...
DaveP, happen to know the working voltage range I'd be expecting to see on said gray/black wire? I'm thinking mVAC.
THIS PART WE WANT TO SEE PHOTOS / VIDEO OF.....:grin:
Never said it was smart. And it's only heavy lift if it's a 53. The rest couldn't lift a pinto. So if spinning the wheels gives a reading that's fine but just put in drive then. Without knowing what plug your reading voltage on how would I know if it's cutting any input or output. And to start another pissing match if it's a range of readings I'm pretty sure it's a variable resistor not just a sensor. Simple sensors look for 1 condition to make the circuit. Show me a real schematic and I'll be able to figure it out more sensibly. Good mechs go to QA not dept supervisor. On a nicer note can you sign my leave chit please
Discussion Starter #15
Never said it was smart. And it's only heavy lift if it's a 53.None other The rest couldn't lift a pinto. So if spinning the wheels gives a reading that's fine but just put in drive then. nah, not if I can get a reading without. safer Without knowing what plug your reading voltage on how would I know if it's cutting any input or output. the sensor is the source, DaveP gave me the wire to read at the clusterAnd to start another pissing match if it's a range of readings I'm pretty sure it's a variable resistor not just a sensor. NO... voltage output from the sensor (source voltage) is proportional to mechanical motion. resistors are a load, not a source. Think of the sensor like a really small A/C generator or alternator. Simple sensors look for 1 condition to make the circuit. Show me a real schematic and I'll be able to figure it out more sensibly. doubtfulGood mechs go to QA not dept supervisor. Been there done that... I'm the Control Chief, that's where the boss wanted me. My job is to ensure unit readiness, not do a Sgt or SSgt's job for him. I'm all about working on the line but it's not my place anymore. I do when I fly, teach nuggets... whatever, but not my primary duty. On a nicer note can you sign my leave chit please lol
don't get upset. I'm just giving you a hard time:thumb:
Discussion Starter #16
No progress this weekend. I was focused on prepping my Jeep Cj7 for sale. Selling that would be great... TRUCK MONEY!!
Discussion Starter #18
Digging up this oldie. So I've just been running a speedo app for the last year or so... Now that the rear end blew up, I'm touble-shooting this gripe again.
I pulled the cluster, looked for any burnt components. Only thing I did find aas the "4x4 high" D24 diode floating around in the cluster and broken solder contacts. That explains the 4x4 light not working. I'm waiting on my cordless soldering iron to charge to fix that. It doesn't lock in to 4x4 anymore but I'm figuring the shift motor finally died. Unrelated issue. It works with a Wrench and I'll get to that later.
So if nothing looks burned or there aren't any broken contacts, it may in fact be a wiring issue. I'm no expert with micro-components and circuit cards but usually you can tell when something has **** the bed on a card.
I guess I'll trace that black-gray wire back.
That's the only indicator not working so maybe the wire coming off the speed sensor is bad/broken and not giving the signal to the speedo/odo.
By looking at the card, the speedo and odo look to be independent back to the plug where the signal comes into the cluster.
I'll keep you posted.
Discussion Starter #19
@DaveP.
When you mentioned gray/blk,
Are you talking about the gray wire with the black stripe on the small black plug of the 3 plugs into the cluster?
Discussion Starter #20
So rear end rebuilt due to eating a carrier bolt. Replaced the VSS while I was at it. Same issue. Speedo sits at zero, odo doesn't track new mileage. Needle does sweep when I turn the key on. Trying to figure out where the wiring actually runs. I've traced the wire loom from the rear diff along the frame rail up to the transfer case but then the loom splits. I guess I'm going to have to cut the looms apart and inspects the wire inch my inch...
1 - 20 of 38 Posts
