i have a 02 f350 7.3. i have a 4 in exhaust and a cortex. dosent seemed like the cortex added much power. i uped the fuel pressure. i know that you could take a resistor off the map to ground as a boost fooler. it worked great on my 00 but i sold it so i cant look at it and see what resistor i need. also i have a stock air intake. i rember hearing something about a diy deal useing a round paper filter from napa. but dont know what one etc....... any other cheap power adders? i dont need to much more but it would be nice it had more than it does now. thanks!!
how did you up your fuel pressure? my truck could use this
cheap power and a 7.3 does not go together.... If want power id sell the superchip and buy a custom tunned 6 pos. chip from either:
Swamps
Tony Wildman
Beans
Gearhead
PHP
etc.
Look into the DIY intake and your gonna want a set of gauges to go with the chip.
pulled the pressure regulator cap off and put a bb behind the spring. the pr is on the drivers side of the fuel filter. it has 2 torx bolts that holds the cap on and there is a fuel line connected to it
already got gauges. i dont want a whole lot of power out of this one. just needs a touch more. i got a 00 that im slideing a set of twins on with 100 hp injectors and some other goodies.
ok cool thanks. btw id say ditch the cortex and go with the edge evolution i have that on my truck and love it. i pulled 277ft with my 02 ccsb only other mods cold air and exhaust. didnt air the tires down at all. didnt feel i did too bad for a first pull
