How hard is it to remove to the hpop cover to the reservoir what is involved, is there a gasket? I want to check for leak down. Thanks
you can pull the allen plug out or even the oil sending unit right on top the reservoir and run a thin object ,screwdriver etc. down to the bottom and as long as its no more than 3/4 of an inch down from the top after an overnight sit your fine
Right on top of resovoir. right side.
Ok thanks I'll look into this I just never done it before and I would like to check it. Have a little bit of a hard start happening.
