1 - 12 of 12 Posts
i have an 01 f-250 psd and when i start it and take off it will do a series of 5 beeps at me 5 times. its not the seat belt beeper and there are no lights on the dash unless someone disconnected one. anyone know what this damn beeping is?
airbag light burnt out, thats what mine does!
Discussion Starter · #9 ·
yup, you guys are right on. i just ran out and scanned it and had two codes, lamp airbag warning indicator ckt open, this would probably be from a burnt out bulb. the other is PAD sw warning lamp inop, anyone know what that code is for or how to fix it?
just did mine yesterday. the bulb in the dash was burnt out. pull out gauge cluster and put in new bulb.air bag light will still be on if the light is out on the passenger switch but the beeping goes away
My truck beeps also. I'm curious did it also beep
sometimes after driving aroundine beeps after I take off then I can faintly
hear it after driving for awhile it beeps then goes away guess I'll check to
see if airbag light is out
1 - 12 of 12 Posts
